Hi!
I have duo2 with BH 2.0.5B. I thought I should be able to stream with VLC simultaneity more channels from the same transponder, but looks like I cannot. When I open one channel is ok and can watch, but if I want to open a second channel from same Transponder the first channel hang but second goes on. I made test with FTA on local LAN. What possibly can be wrong? Or it is BH / VU+ limitation? Or should I use some plugin or some settings tuned up?
Thanks!
Thanks!
