Streaming/Transcoding/M3u - lots of questions
beka2
Hi everyone,
I have a few questions about this topic.
Just for context, I'm using 2.1.7
Continuing the talk from:
http://www.vuplus-community.net/boa...scoding-icon-missing.26587/page-2#post-222135
1. What is the status on the transcoding icon?
Has it been found why its missing?
3. Receiver is listening on port 8002, but I cannot watch transcoded channel, why/how to fix?
I tried with MPC but after trying to open the stream for 20 seconds, I get only a black screen with no audio and no video.
3. In VLC I don't know how to try it because it seems it only reads M3U files? I cannot open a network stream with IP:port.
http://vuduo/web/stream.m3u?ref=1:0:1:32B:24:36:CE40000:0:0:0: - It Works in VLC
http://vuduo:8001/1:0:1:32B:24:36:CE40000:0:0:0: - It does not Work in VLC
Is there any specific format for this, or how does it work?
4. How can one check transcoded streams with that .m3u format?
5. How can I make the box default to no channel playing?
I managed this by going to the Tuner list, try to change one of them, and then return to the channel preview.
This freed the Tuner that was being used locally by the box, although is there any way to do it automatically?
Regards.
