Hi, everyone.
I'm using Black Hole 3.0.2.H Kodi for my Vu+ Solo2.
everything is working fine kodi etc..
the problem is when I add a stream url to my fav channel's list it works for upto 10 seconds then the picture freezes not the box, however if I press the <OK> when it freezes it continues to play for another 5-10 seconds and freezes again until I press the <OK> button again.
I'm guesing this is a buffer issue does anyone knows how can I fix this.
thank you.
thank you.
