Streams broadcasting
andycpp
I want to build the following configuration:
Dish -> Solo2 -> Ethernet Switch -> TV1 / TV2 / ... on TV I want to use built in DLNA player to select the channel.
So I need to setup DLNA media server on the Solo2 and add channels to the list.
Would you please suggest me how to do it step by step? I've managed to start DLNA media player but can't add my favourites channels to the list (to be selectable directly from TV, like files in Twonky/Windows MS). Is it possible to see different channels from two TVs simultaneously (one - through tuner A, second - through tuner B)?
I continue to explore the possibilities, but stuck with Server Tuner - it should create in the /mnt/hdd/tuner set of files with channels URLs, but then I start Server Tuner is just creates empty /mnt/hdd/tuner folder, no files inside. What I'm doing wrong?
I use USB flash drive with a lot of space, and yes, I've created favourites list. Maybe some logs available to explore and find out the problem?
