Stuck at boot
rnone
Hello there,
New to vu+ world, I'm trying various images. The problem is that only official images completes booting. Other get stuck at boot with either spinning gears (Pli) or Atom (BH. Tried 1.4.2 and .3) and message "starting enigma II" forever.
The machine is brand-new, not connected to anything.
Is there any debugging/logging tools and tips on how to find what happens ?
TIA for any advice.
Hello there,
TIA for any advice.
This is very strange, can you tell us step by step how do you flash imgs?
Power-off the Vu+ ,,,wait for awhile!
Then,
If U using USB 2load the images (I find it to be best way),,,,check the downloaded files and make sure they are 100% complete,,,,,and no need to make or name a folders@USB ,,,,just extract or unzip directly 2USB!
Then connect USB@front and load 2Vu+ as usual!
Gdluck!
