Hi Can you help? I Switch on and only the white stand by light is showing on the front panel, the Bos does nothing ...seems dead! Any Suggestions?
Thanks Mike
Dea Alex,
Thanks for your reply. I think think that job might be slightly beyong my soldering capability, do you know anywhere where I could get it repaired?
Yes, any electronic technicians can do that, provided that this is the problem. But you can see yourself if your capacitors look like the one blown up in my pictures.
