stuck on start screen
hull2012
3 days ago i decided to update the image in my box as it had not been done for a while.
i got a brand new usb dongle and formatted it. and then downloaded the latest bootloader zip to my pc, and then extracted the file to my dongle.
i turned my box off, and plugged in my dongle.
after turning my box back on, it read the usb, and loaded the new bootloader.
i then removed the dongle, and turned the box off again via the rear power button.
I then re formatted the dongle via my pc, and downloaded the latest bh image again to my pc, and then extracted to my dongle.
i then put the dongle in my vu duo and turned the power back on.
Again the box read the dongle, and erased the flash, and loaded the new image.
When it had finished i again removed the dongle and powered off the box for 2 minutes.
When i turned my box back on it went through the motions and it got as far as the start screen but no further.
All i get is a spinning bh dial in the corner for hour after hour.
I have since then loaded lots of different images old and new, but all get as far as the start screen and no further.
there is no other usb dongles in the machine, and i have never installed any HDD in it.
i can use vucc to telnet, and i can ftp the box, but when i try to web-control the box i get the cannot conect web page.
My box is not a clone, and it has worked fine for over 2 years, but now it has got me baffled as to why it sticks on the starting screen and goes no further.
all help will be gratefully appreciated.
