Stuttering when watching movie on external USB or E-SATA
Bulent Oner
Hello,
I have recently bought a Vu+ Duo. To be honest, I couldnt decide VU+ or Azbox but channel transition speed was very bad on Azbox so I bought Vu+ Duo.
Sattalite issues Vu+ Duo is great. But when I tried to watch a movie on USB or E-SATA it played with stutter especially in action moves it is increased. And it is getting annoying.
Do u have same problem like that?
Or Should move to Azbox?
Note: I didn't attached internal HDD yet. My image is BlackHole Vu+ Duo 1.4.5 Multiboot
Thanks.
Hello,
Thanks.
You can solve all your issues by installing an internal HDD.
I use it and it works perfectly and I think it's the best way for recordings.
PS: I'm sure you bought the best decoder ;)
