Subservices on OBH
AlexWilMac
Moderator
As the GREEN button is reserved to the system and it's not configurable by the "Button setup" menu, I tried to assign to LONG GREEN press the selection of subservices but it just doesn't work.
I initially thought that, just because GREEN is reserved, such a command might be within the ones you see by LONG BLUE pressing, as a choice.
Is this function impossible to use under OBH at the moment?
Might be it will be included somewhat in the future?
