Subtitle Player 3.01 = crash crash !
What exact file do you use when install??
You must use this one
Subtitle Player 3.02 IPK mips py2.6 (python 2.6 OE1.6)
also it would be better to remove old versions before and after that install ipk and put a fix.
The problem is in wlan connection because there is not internet present in moment when enigma is booting - use cabel and there will be no probelm.
Your crashing could be connected with ram usage and using a lott of epg - so after you do above described procedure if there is still crash please make swap and there will be no problems (128mb will be ok)
Hi to all
I am new in forum and want to know
- What does subtitle player do ? is it necessary to install?
- I want use a modem router ( 4 port) what kind of Lan cable I need between receiver and router cross or direct?
thanks
