Subtitles fixed?
bjorntj
In 1.6.2 is says subtitles fixed, does that mean I can change the size (and colours?) of the font from an menu and not by changing the xml conf file? And if so, where can I find this settings in the menues? I have not been able to find the menu for changing subtitle properties?
Regards,
BTJ
They only fixed linebreak (which was big problem with all e2 cvs)
Unfortunately they did not fixed any of the things that you mention in above post, I asked for those fixes too when the fix cameout, but unfortunately it seems noone listened.
i had also problem like a big subtitle but i found a program u can just change the fonts like 30 than it will be perfect it is fontmagnifier
