But you`ve to understand that not every movie is broadcasted with subtitles, if they do they`re available.
But for recordings only with: audio button, yellow button.
Hi
Subtitles button on top row works fine for live shows/films, but when playing back recorded shows/films the only way to bring up subtitles is a mult-key press through the audio menu.
The same short-cut available using the subtitles button when viewing a live feed /should/ also be made available when viewing recorded content.
Agree, by the way It works fine in my Solo, but not in Duo??!
I suspect it's just a keymapping issue (keymap.xml?) but I've no idea what voodoo you need to do to enable it
Bit annoying isn't it..
Are there any keymap files in the media viewer plugin folder (I *think* that's the thing that's used to view recordings anyway) : /usr/lib/enigma2/python/Plugins/Extensions/
I'm not near to my Vu at the moment so I can't check right now, I'll have a dig later myself too
