Hello, could you please enable greek subtitle support for movies?
I have the greek *.srt file in the same folder as the movie but vu+ doesnt recognise greek.
I tried this method, and it helped me with arabic subtitles.
1. Open srt file with Notepad++
2. Press Ctrl+A (this will select everything)
3. Press Ctrl+C (this will copy everything)
4. Change the encoding to UTF-8 (your text will be scrambled)
5. Press Ctrl+V (this will paste the copied text)
now you can save the file with the new encoding.
I hope this will work for you
for greek subs
open your file notepad++,from bar menu choose encoding ,then caracter sets ,greek 1253.
then from encoding again choose convert to utf8 and save the file.
