Suomipoeka 1.0.1
DanielFran
BH Lover
Enhanced movie list V1.0.1 modded by Coolman & Swiss-MAD
13.11.2010
Enigma2-plugin-extensions-suomipoeka_1.0.1_all
Changelog V1.0.1
avi and mkv files are now also available with the file type
Film List all set to left, tags now appear instead of the icon's
(For Skinner: Use new value -> CoolMoviePos = "30"
German translation changed "start Last Play" to "last film" so that fits with the blue button on a row.
Skin's adjusted.
Main Features
MovieList:
- Fast operation compared to the original E2 MovieList
- Full directory support
- More control over the movie files (move, delete, dir create, empty dir delete)
- Multiselection (pressing the video-button on a movie) for all available operations (delete, move and playlist)
- Files can be moved or renamed during playback / recording (Linux filesystem feature)
- Files can be deleted while being played (playback will be stopped or file is removed from playlist)
- Ongoing recording is shown in the movie list
- Recording can be stopped via the movie list
- Trashcan option (if you don't like it, put "days remain" to 0 and "trashcan hide"=yes)
- File operations done in the background (currently 3 shell execution unit instances, can be scaled up if required)
- Files being moved across mount points e.g. from internal HDD to an NFS/CIFS NAS share (or vice versa) do not block the GUI
Other features:
- Allows usage of different GUI and EPG languages without messing up the EPG
- Automatic cleanup of done-timers
- Automatic daily restarting of Enigma (prevents device crashing in heavy usage)
- Possibility to speedup the remote control key input
MovieList Controls
- Cursor keys: navigate list normally
- Info: standard Enigma EventView
- Menu: pops up the MovieSelectionMenu
- TV-button: reload current directory
- VIDEO-button: Select / deselect files for multiselection
- TEXT-button: Multi-selection *toggle* begin / end
- OK: play current movie selection / playlist
- RED: delete selected movies (permanently if "days to remain in trashcan"==0)
- GREEN: Alpha sort / date sort toggle
- YELLOW: Move currently selected movies (LocationBox opened if cursor not on top a directory)
- BLUE: Movie home / Play last (configurable)
FAQ
Q: What is the "cifs* files operation" setting?
A: On Samba CIFS filesystem Linux creates "cifs"* (randomly numbered e.g. cifs7645) files when files that are being used by some process get deleted by some other process. For some reason these files are not deleted by the filesystem when the first process using the file finally releases it. I added this option when I was using recording over a Samba CIFS mount. This way I didn't have to worry about these grabage files left on the drive. If you're not using a CIFS mount you can ignore this setting as it will have no effect.
Q: What is the "cursor to newest" setting?
A: The "cursor to newest" settings simply move the cursor on top of the newest recording when the list is opened (from tv mode or playback mode). By setting on the reversed list order this effect will probably be more visible.
Very good plugin, it use to crash my DMM back in the old days, looking forward to try it on VU.
I love this plugin.
Use it with Black Hole 1.7.1 and EleganceHD_P skin (also works perfect with 1.7.1 with Rihanna7)
