Suomipoeka V 1.0.0
Main Features
MovieList:
- Fast operation compared to the original E2 MovieList
- Full directory support
- More control over the movie files (move, delete, dir create, empty dir delete)
- Multiselection (pressing the video-button on a movie) for all available operations (delete, move and playlist)
- Files can be moved or renamed during playback / recording (Linux filesystem feature)
- Files can be deleted while being played (playback will be stopped or file is removed from playlist)
- Ongoing recording is shown in the movie list
- Recording can be stopped via the movie list
- Trashcan option (if you don't like it, put "days remain" to 0 and "trashcan hide"=yes)
- File operations done in the background (currently 3 shell execution unit instances, can be scaled up if required)
- Files being moved across mount points e.g. from internal HDD to an NFS/CIFS NAS share (or vice versa) do not block the GUI
Other features:
- Allows usage of different GUI and EPG languages without messing up the EPG
- Automatic cleanup of done-timers
- Automatic daily restarting of Enigma (prevents device crashing in heavy usage)
- Possibility to speedup the remote control key input
MovieList Controls
- Cursor keys: navigate list normally
- Info: standard Enigma EventView
- Menu: pops up the MovieSelectionMenu
- TV-button: reload current directory
- VIDEO-button: Select / deselect files for multiselection
- TEXT-button: Multi-selection *toggle* begin / end
- OK: play current movie selection / playlist
- RED: delete selected movies (permanently if "days to remain in trashcan"==0)
- GREEN: Alpha sort / date sort toggle
- YELLOW: Move currently selected movies (LocationBox opened if cursor not on top a directory)
- BLUE: Movie home / Play last (configurable)
Znači bolja i brža kontrola nad snimcima te više opcija nego što enigma standardno pruža.
