SVDownloader 2.0
dalraist
Vu+ User+++
SVDownloader 2.0
Description:
SVDownloader is a plugin for Enigma2 which downloads vHannibal or Cyrus settings without deleting your DVB-T favourites category.
Prerequisites:
pyhton-zlib - If you do not have python-zlip package already installed, go to Menu -> Setup -> Software Manager -> Advanced Options -> Packet Manager, select python-zip packet and install it.
If you do not find Advanced Options, you should first activate Expert mode in Menu -> Setup -> Customize
Installation:
Download the plugin, place it into directory /tmp/ of your STB, and install it through addon manual install procedure.
Restart Enigma2.
Usage:
When you start the plugin, you just need to select which type of settings you like (vHannibal and Cyrus are supported), how many feeds you want and choose if you want to keep your DVB-T favourite category.
Then you can hit Blue button.
Eventually, the plugin will ask which is the category you want to keep, and then it starts intalling new settings.
With Selection option, you'll be asked for satellite set you like.
History:
1.1 - First Release (Beta)
1.2 - Intent to use internal unzip. Hold for now due to other issues
1.3 - Fix Cyrus Motor Download Green Screen
- Fix Bouquet download when change Setting source
- Automatic Setting Reload implemented
2.0 - Added Selection feature. You can select any set of satellites you like. It will take a little longer to install
- Fix crash on version button
