SVDownloader 3.0
dalraist
Vu+ User+++
SVDownloader 3.0
Description:
SVDownloader is a plugin for Enigma2 which downloads vHannibal or Cyrus settings without deleting your DVB-T favourites category.
Installation:
Download the plugin, place it into directory /tmp/ of your STB, and install it through addon manual install procedure.
Prerequisites:
pyhton-zlib - If you do not have python-zlip package already installed, go to Menu -> Setup -> Software Manager -> Advanced Options -> Packet Manager, select python-zip packet and install it.
If you do not find Advanced Options, you should first activate Expert mode in Menu -> Setup -> Customize
Usage:
When you start the plugin, you just need to select which type of settings you like (vHannibal, Cyrus and Onopkos are supported), how many feeds you want and choose if you want to keep your DVB-T favourite category.
Then you can hit Blue button.
Eventually, the plugin will ask which is the category you want to keep, and then it starts intalling new settings.
With Selection option, you'll be asked for satellite set you like.
Modify separators.cfg to customize bouquet separators
History:
1.1 - First Release (Beta)
1.2 - Intent to use internal unzip. Hold for now due to other issues
1.3 - Fix Cyrus Motor Download Green Screen
- Fix Bouquet download when change Setting source
- Automatic Setting Reload implemented
2.0 - Added Selection feature. You can select any set of satellites you like
- Fix crash on version button
2.1 - Onopkos Settings added
3.0 - Support for translations (English, Italian)
- Prune out DVBT category with the same name from the list
- About (Help button)
- Create DVBT category ordered by LCN
Not work for me with 1.4.5 green screen..and error when install..
Dalraist please read my post in italian section.
thanks
zio
how can we uninstall this plugin now?
i uninstalled it from panel but i still see it in plugins even if i restarted enigma
That's strange, I uninstalled it and I did not find it in the list anymore
