Hi
Maybe a simple operation but how do I switch tuners between A and B ? can I use the remote or is it a menu operation? VU+Duo2 with Blackhole 2.0.9. I have B static on 28e and A motorized
jb
The actual switching between the two tuners should be done automatically, according to what channel you are on if everything is set correctly.
Use rhe remote and the receiver's menus to enter the correct antenna settings for the two tuners. Then scan the satellites or load a channel list.
@Johnb71 : As I understand, your are mostly using tuner B. Menu>Setup>System>Customize, set to Expert, third line from end of list, Preferred Tuner from Auto to B. BH 2.0.9.1 tested.
Hi
Thanks for the replies guy's, sorted. Ok with linux from the old dbox2 days, but this had me stumped. Too many Menu's now but can't complain, just need the time to go through and experiment them all : lol
jb
