Switching off the front lights
Deano
Hi. Is there a way to switch off the round blue light and the three smaller lights on the Ultimo? I've been searching through the options after installing BH 2.1 but can't find anything. Hopefully I'm just missing it!!
Thanks
Because they are very, very bright and very distracting in a darkened room when watching a movie on a projector!!
A bit of black insulation tape on the front might be the answer so...
Stick a piece of cardboard in the front and remove during the daylight.
I don't have my ultimo any more but try menu/setup/system/display setup
It is not a software issue....voltage/brightness to LED'S only controllable by hardware modifications ..VR maybe.
Yes, I checked on my Utlimo and it's in the plug in folder. Through this plugin you can modify led brightness oy even turn them off.
