Duo2 Switching ON from a deep-stanby using remote controll
So if I do it in sort period of time it work ok, but if left it a long time in Deep Stb, do not power up with remote.
jwlalek ------ Can you check it in your box,pls ????? -
I haven't noticed that kind of problem.
I usually can power on the Duo2 with the remote after almost 20 hours of deep standby (for example power off at 01:00, power on at 21:00)
This is exactly same what my receiver does.
OK. This morning ( after 13 hours in Deep Standby), machine power up correctrly with the remote control. Thas the he has to do. OK.
Action done yestaeday before this, was: in BH Speed Up, disable the Remote Control Code plugin, restart GUI and after that enable the plugin again. Restarted GUI and some hours later, power off ( Deep Satndaby).
This morning , as said before , power up correctly.
So for my is OK . Thaks a lot to everey one.
You find it perfectly normal?
That without installing additional plug-in receiver is not activated with the remote control!!!
In BH that plugin is installed and activated at startup by default.
Apparently it's required to resume the box with the remote only from deep standby.
Otherwise it could be deactivated or uninstalled, but honestly I can't find good reasons to do so.
