System reset
petine
I am in big trouble; I have configured the satellite settings and now I can't restart my Vu+Solo2.
Is there a sort of reset of the system. There is nothing on it in the manual.
Is there anyone who can help me. :help:
Try to switch off the box by Solo2 rear switch and then try to turn on the box.
I have done that already and also have I disconnected the satellite cables and returned to the box, without success.
Can you please tell me how to do that.
You need an empty usb stick FAT32 formatted and the Solo2 has to be turned off by its rear switch.
Download the image and unzip the file, you will find a folder named vuplus.
Copy the folder vuplus (with all its contained) into the usb stick.
Connect the usb stick to the Solo2 front usb port and when appears the relative message on display press the Solo2 power button to upgrade the box.
When the upgrading will be finished, the box will autostart.
Should I install the image: "Black Hole Vu+ Solo2 1.7.9-3" ??
And how can I check the FAT32 from the stick and how to format it to FAt32.
