System time ... wrong no change...
riccardomagno
Hi, I have this problem in my Vu+Duo2 1 tuner DVT 1 tuner duo Sat, my system image Black Hole 2.06...
system time is one hour in the past (living in the past Jetro Tull ??...)
I have tried by telnet in format date -s 02111130... successfull only for few minutes... after retur in the past.. has anybody a solution ?????
Have you correctly set your time zone in system settings?
Sorry for this apparently obvious question, I've to start first asking about the most basic settings...
Hi,
yes and after the reboot....the hour changed with telnet return to the past.....(back to the future.. sorry back to the past....)..
Idea !!!!!!! in other images (CT9000 Extrend) there is an option to manually change the system time and it goes well.. there is in BH an auto trasponder time to stop?....
AFAIK a manual clock menu setting is not available.
I'm in Italy and don't have any clock/time problem.
Do you have a DTT tuner?
I've one in my Duo2 and I've set the priority to DTT tuner, so probably my clock is synchronized with a DTT channel broadcast.
As a last resource you can change your time zone.
Hi,
problem solved by the DDT way... preferred tuner DDT... telnet date -s 03110040...reboot now I' living today....
Thanks a lot
