SystemTime Plugin Error
mdno
hello
I Have problem with my solo4k time setting
in my old vu solo use Systemtime plugin but in solo4k get error probably because of DMIPS cpu.
it says:
Execution Progress:
/bin/sh: //user/bin/ntpdate: cannot execute binary
file:Exec format error
Execution finished!!
Why Time problem dont solve in black hole until now?
please help me how set box time ?or any other working plugin?
Please write, what plugin you are trying to load? I think it is for mips architecture, if you used the same on your solo.
Try enigma2-plugin-systemplugins-systemtime_1.4_all.ipk - as author writes, from v.1.3 Solo4K is supported.
hello
I dont know there is version 1.4!
google it but find v1.2
test it and worked.
Big Hellp.Thankyou so much.
Do you know a source for updated plugins can download by pc?
The main and the most reliable source is plugin creator and maintainer. If you'll google "Dimitrij systemtime" you'll find v.1.4 in openPli forum ;)
hello
test it and worked.
Or follow this posted link --> http://www.vuplus-community.net/board/threads/systemtime-plugin-error.29227/#post-213600
Thanks @Vytenis P.
