O One Dream Vu+ Newbie Nov 14, 2011 #1 Hi , i like to know how i can install these files on Vu+Uno ? thanks ..
Matrix10 Administrator Nov 14, 2011 #3 I do not know, we do not have skins with tar.gz only with .tgz and the skins that were not specifically for BH images you can not use . You you can rename tar.gz to >> . tgz Copy the tgz file to / tmp install manual with green >> yellow >> Manual install BH packges
a911 The BH Lover Nov 15, 2011 #4 Matrix10 said: You you can rename tar.gz to >> . tgz Click to expand... Please MX10,,,I would like to know more,,,is it just right-click PC mouse and edit the name? And it will work....like .tgz file! Thanx a911
Matrix10 Administrator Nov 15, 2011 #5 The difference between .tgz and tar.gz is only , the filename. So you can edit/rename files.
Tamaki Administrator Nov 17, 2011 #6 One Dream said: especially the skins Click to expand... Be carefull because if you install a skin not design for the specific image you are using you risk to be unable to use your img unless you reflash it.
