teletext plugin
Can u tell me where dowload the original version of BlackHole?
Thanks in advance
Inviato dal mio Samsung S3 con Tapatalk 2
You can take a look into Software Manager on your box
Already view, don't find, other solution?
there is a plugin tuxtxt, but if i want install says "0 package installed o removed..."
Thanks
can i use this command?? i try but the package doens't exist!
opkg install enigma2-plugin-extensions-tuxtxt
o
opkg install enigma2-plugin-extensions-teletext
my problem is the plugin doesn't works!!! i want to install a version!
The plugin works fine.
Are you sure that you are using it on a channel transmitting teletext?
How do you start it?
There is a button to start teletext.
