Telnet access work with cable but not with wireless?
Euphoria
Hi,
Im have a Vu+ Solo2 with original 300Mbps wifi dongle connected in back usb, a usb 16Gb kingston also connected in the back, 320 hdd inside with the last BH 2.0 revB.
at first im use the cable and can access to telnet, ftp, etc... after im connect usb wifi, reboot the box and configure the wifi (using the wizard, use dhcp), disconnect and desactived the eth. cable. internet work fine, im can update and install plugin but im dont have access from my computer! im try to made a ping but no chance. im see the ip address in the green-blue and select ifconfig and is ok.
any idea?
Thx in advance.
Hi,
any idea?
Thx in advance.
Very strange! In my home I've only wifi connection and Solo2 has the original Vu+ 300Mbit dongle and all works great ....
Have you used DHCP or static IP on your box?
Im have dhcp with a static ip in the router (im use reserved ip with mac)
im try to use a static ip in the box and now im have access, im try to active dhcp again and now all are ok!!! the only diference is yesterday with the ifconfig, im dont have a broadcast ip and today, when im config a static ip yes. when im go back to dhcp al also have a broadcast ip.
If someone have a similar problem, try to reboot the router, change to dhcp to static in the router (ip, mask,gateway and nameserver), when is work try to activate a dhcp again and check the ifconfig in green boton-blue boton. in my case im dont see broadcast ip but now yes!
Thx all for read and angelofsky for tips :)
