Terratec DT XS Diversity freezes after some zappings
ihavu
Hello angelofski1980 !
I need your help:
my DVB-T stick works, but there are some problems:
After some channel switches the stick freezes. especially if it is zapped to another channel range p.e. from V to H -band.
If I restart the Solo2, it works again with the new selected channel.
But there is another possibility to make it work :
I go to the Tuner Menu, deactivate and activate the DVB tuner, then it works also again.
So is it posible to reset the tuner automatically after each channelswitch?
Probably the error is in the driver config, because
in a linux driver description is printed that the terratec needs a special config:
"Forcing the activation of LNAs (Low Noise Amplifier)
You may have to force LNA to get this card working:
In /etc/modprobe.d/options add:
options dvb_usb_dib0700 force_lna_activation=1"
But how to change in Blackhole?
Thanks in advance for your help
I have added logs.
btw with windows there are no problems, so I don`t think the stick is nok
I need your help:
I have added logs.
Dear angelofski1980!
I am a lttle bit disappointed:
No answer and even no look to my logs.
What is going wrong?
Seems all OK.
Have you tried with latest BH image? Use also an external powered hub USB to avoid power problems to your stick instead to get it from your box.
Seems all OK.
Hello angelofsky1980!
Thanks for answering. I updated BH Image to BH 2.1.1.
Now the situation is little bit strange.
First after starting the solo2 it seems all to be ok : the Terratec was found from system. See output1 log.
But after one zap to DVB-T the Solo2 loses the Terratec DVB-T configuration see output2.log.
What could it be?
Please help
Thanks in advance
Now I am using an active USB Hub.
But the same as before:
Terratec is found from BH, but after some zappings the terratec freezes, (like described in first post )
So my questions again:
Is it possible to change the configuration of the firmware/driver dib0700? s.a.
Is it possible to restart the driver after each DVB-T zap?
What can I do elsemore?
in the log is often printed:
"<0>### XPT_MSG (W2, bit 15) fired 10000 times"
What does it mean?
Thanks in advance
What does it mean?
Thanks in advance
I'll verify the "<0>### XPT_MSG (W2, bit 15) fired 10000 times" message that is very strange.
