holychihuahua
I have a vu+ duo2 with black hole installed last week. The sattelite works fine but not the terrestrial tuner. What are the correct settings for this tuner in south east england.
Europe, Middle East DVB-T if you have DVB-T signals or DVB-C if you have CableI have a vu+ duo2 with black hole installed last week. The sattelite works fine but not the terrestrial tuner. What are the correct settings for this tuner in south east england.
What about the other settings?Europe, Middle East DVB-T if you have DVB-T signals or DVB-C if you have Cable
Yes. What would I be checking the terrestrial file for?Have you tried scanning in any terrestrial channels?
You might have to check the terrestrial.xml file.
