The time is 15:00 Fri 27 Mar
but after power on is another date and time
I had this problem before and I lost the timer
what do i do now, reinstall the image?
Is it BH or OBH the image are you using?
If it's OBH, you can sync the time not using transponders but by an ntp server: MENU/Setup/TIME
and change the option
Sync time using
to choose NTP.
If you use BH... there should be a more complex workaround. Or you may change the first channel.
