Luar
The TYPES Of DiSEqC
Can help you get questions ...
DiSEqC 1.0 –
Is the basic version of this switch type, being one-way, which means that only
allows the issuance from the receiver to the switch of the same type.
Controls up to 4 inputs and one output.
DiSEqC 1.1 –
Similar to the previous one, but can control up to 16 signal inputs, by allow
switching to other similar switches.
DiSEqC 1.2 –
The primary function of this version is the ability to move antennas, by use of a
engine designed specially for this Protocol. On the other hand, can also, and at the same time,
like the DiSEqC 1.1, create other four control signals and select up to 16 other antennas
DiSEqC 1.3 –
Equal to 1.2 but with USALS (with algorithm for calculating the positions of satellites as its geographical position therefore requires the geographic locations of the location of the antenna sat)
DiSEqC 2.0 –
Similar to version 1.0, but, in turn, in addition to switching allows the dialogue in two
senses so that it can provide data on switching to the operator.
DiSEqC 2.1 –
Similar to DiSEqC 1.1, but with return information to the operator.
DiSEqC 2.2 –
Similar to DiSEqC 1.2, but also with "feedback" data relating to
positioning and switching.
The possibility of feedback is important, insofar as they can at any time assess the State of installation.
DiSEqC 1.0 –
DiSEqC 1.1 –
DiSEqC 1.2 –
DiSEqC 1.3 –
DiSEqC 2.0 –
DiSEqC 2.1 –
DiSEqC 2.2 –
