time is wrong
x-xxxA
You can make a search in the Search Forum for 'Date and Time is wrong and I can't fix it' and don't forget to thick the 'Search title only'
AlexWilMac
Moderator
Please: be specific: there is a perfect option in Setup/Time submenu where you can set the NTP sync instead of using transponder time.
And if you absolutely want to use transponder time, be cautious to the channel is the first in your first bouquet.
But NTP sync is the best way to forget about transponder's time, often unreliable.
