my solo2 blackhole 2.1.1
i set the timer many times to rec. but i found not any rec. after time done
i sure of the timers date and time all is correct i didnt knew why the solo2 not rec. the timer
Have you set the recording path correctly?
Does it record when you press the record button?
Is this onto an internal hard drive?
My timers always work, even when the receiver is left on, or in standby mode.
yes the path is correct and i rec. by press the red rec. button and rec. work
but sometimes the timer rec. not work
i think .. can i correct the time hour of solo2 sometimes its not correct time
think its my be happen when timer rec. work i dont knew
