TLC Sweden
jonas111sanoj
Hello
Could you fix the EPG for TLC sweden it shows the same epg as travel channel
Id for TLC sweden is: 1:0:1:1A1:4:46:E080000:0:0:0:
Thank you
Hello
Thank you
I think this issue rlated to provider!
However, try to re scan the Channels (The provider) , may be it will be fixed or use epg-cross plugins!
RgdZ & GdLuck!
a911
