TodoDream V-2.3 VU+Duo
segredo
Broadly speaking this image backup:
-OpenBlakhole
Full BlakHole-Blue Panel
"All the drivers for USB-TDT Blackhole (Blue Panel) (default is that of the Black Fly)
-Pluging + *****-2.1.3 (put your *****.conf in / etc /)
"Libraries of the current DM-8000 (ICVS Gemini-P-3)
-Drivers Codecs + DM-8000 (ICVS Gemini-P-3)
-Bootlogo TodoDream
-Spinner TodoDream
VU + BlakHole-Kernel
Weekly EPG-D + located in the "technical channel" of D +.
* Fixed Bug from the display (OSD)
-Fixed ecm-time (nan)
-Maintained the operation of the second InfoBase pressing OK button twice + analog clock.
In summary,
has the scripting level features, BlakHole full panel, but with the libraries, codecs and the latest possible drivers dm-8000, the reason is that dm-8000 uses the most current versions.
THX javier3034
