Tp-Link WN822N V2 300Mbps problem on BH 2.0.1 [ath_9k]
HouseNight
Hello,
I have a network card TP-Link WN822N V2, which is based on ath9k_htc driver.
Apparently, in the image BH 2.0.1 are included drivers needed to run the card. TP-Link WN822N not react at all when connected to the receiver and is certainly efficient.
I look forward to your help in launching the USB dongle for VU + Uno.
Thanks in advance for any help :)
Hello,
First of all follow instructions on the thread http://www.vuplus-community.net/board/threads/wifi-drivers-how-to-report-problems.11437/ to report minimal details about your equipment
This is the id of the card
USB\VID_0CF3&PID_7015&REV_0202
Now I have uploaded a new image 2.0.2 and the card still does not work.
I created a file wifi.txt by BH Script Panel.
Just do not know if I had to do it while connected to the Internet via Ethernet or the connected TP-LINK TL-WN822N.
I do not know English fluently so please forbearance.
Still waiting on a patch needed to run this card TP-Link.
I've checked drivers sources and your device is already included but I've detected that a firmware file is missing.
I've added it to BH today and I hope it can be avaiable via online updates soon
What revision is your device?
I've made a rapid search into Google and seems it's already supported.
I have problems with TP-LINK TL-WN7200ND too.
For WPA/WPA2 I can't get IP/Netmask/Gateway by DHCP.
When I test the network I get:
- WLAN connection OK (green)
- Wireless Network connected (green)
- DHCP enabled (green)
- IP Address unconfirmed (red)
- Nameserver unconfirmed (red)
I tried to use a static IP, but it does not work too.
WEP mode works correctly.
Hard: Vu+ Uno
Soft: BlackHole 2.0.2 rev. D
Stick: TP-LINK TL-WN7200ND (ver. 1.0, 150 mbps, RT3070STA)
Router: D-Link DIR-655
wifi.txt attached.
