transcoding help
gus
I have manage to stream my vu duo2 outside my home network, it worked OK, HD channels did not work, but I could stream SD channels, there was some stuttering, will changing the Birate and Framerate in the transcoding setting help reduce the stuttering. Currently they are at
Birate: 2000000
Framerate: 30000
should I reduce theses
had the same problems, i have changed Birate: 2000000 to Birate: 1800000 and it is working for me. I use BS Player in Android tabled as the player with HW accelleration
I put a new driver
driver update
20130916
- Fix vtuner problem(duo2, solo2)
vuplus-dvb-modules-vuduo2-3.3.8-4.4.3-20130916.tar
and now the stream is no video, only audio
What do?
