Transcoding problems on VuSolose v2 with OBH 0.1
Gvv
Hello,
I have trouble getting transcoding to work on my vusolose v2 with OBH 0.1.
Normal SD streaming works, however when streaming HD it's stuttering (logical)
When trying to stream with transcoding nothing happens....
Has any bode have experiences with transcoding on OBH 0.4 or OBH 0.6 or BH3.02
Which image works best with transcoding on a VuSolose v2?
Thanks,
G
Sorry to say but:
1) using 0.1 when we are now at 0.6 is a little bit strange.
2) If you just don't want to "risk" to loose your 0.1 status, you can always save a fullbackup, install the 0.6 (and perform the updates online) and see what happens. If you are not satisfied you can get back to the immature 0.1.
