Hi All,
I have a Duo2 and recently tried to put the transcoding to work but with no success... the typical original stream in port 8001 is working and OK (even outside my LAN). Though, the transcoding feature seems to have 2 issues in my case:
1) the transcoded stream seems to start and being sent out of the Duo2. I've set a minimal rate (500K, 160x320, 30fps) and when I check it in my MXplayer in my android phone a black screen appears... When I see the details of the stream it's there: 160x320, 30fps, AAC for audio etc... as it was supposed to be but no image
(the same setup with the original stream works OK, and this is inside and outside my LAN)
2) when I request the transcoded stream from my mobile I start to get NO AUDIO in my TV (not that this is too important, since when I request a transcoded stream for sure I wont be at home...) My TV is connected by SCART.
I really want to solve point 1 since it's one of the reasons that I bought the Duo2. I'm on BH 2.1.6.1.
@Neblinio can you post your Transcoding settings (included the advanced ones please)? just to check if this is something to do with it...
Thks in advance for all help!
