Transparent skin
Hello matrix10 do you think you will make a transparent skin.
Kind regards
Seth
This is for Open Blackhole:
Press on your RCU <MENU>; <SETUP>; <SYSTEM> <AV SETTINGS> ... change OSD TRANSPARENCY settings.
See it too on Blackhole 2.1.7.
The same thing but --> OSD VISIBILITY
Regards
