Request TrendNet TEW-648UBM driver? [RTL8192CU]
St0nE
Hi!
Is it possible to connect this device to Vu Uno?
As i know, this is Realtek RTL8192CU chip, VID 20F4 PID 648B.
If is not possible right now, can i hope what you will make support this device in the future?
Thank you.. With BR..
Hi!
The device is compatible with Vu+ boxes.
You can try and ... if is not detected we will add support for it :)
Yes, it is working... :) Thank you...
But working not stable... :cry:
I'm using TPLINK TL-WR1043ND, with WPA/WPA2, without DHCP...
It is possible to do something for better result?
Reply from 192.168.0.120: bytes=32 time=5ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=387ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=471ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=2480ms TTL=64
Reply from 192.168.0.120: bytes=32 time=10ms TTL=64
Reply from 192.168.0.120: bytes=32 time=8ms TTL=64
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=483ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=535ms TTL=64
Request timed out.
Reply from 192.168.0.4: Destination host unreachable.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=2602ms TTL=64
Reply from 192.168.0.120: bytes=32 time=4ms TTL=64
Request timed out.
Reply from 192.168.0.120: bytes=32 time=1123ms TTL=64
Request timed out.
Reply from 192.168.0.120: bytes=32 time=1134ms TTL=64
Reply from 192.168.0.120: bytes=32 time=6ms TTL=64
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=2185ms TTL=64
Reply from 192.168.0.120: bytes=32 time=9ms TTL=64
Request timed out.
Reply from 192.168.0.120: bytes=32 time=1201ms TTL=64
Reply from 192.168.0.120: bytes=32 time=3ms TTL=64
Reply from 192.168.0.120: bytes=32 time=7ms TTL=64
Request timed out.
Reply from 192.168.0.120: bytes=32 time=3227ms TTL=64
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=3289ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=1336ms TTL=64
Reply from 192.168.0.120: bytes=32 time=1999ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=2463ms TTL=64
Reply from 192.168.0.120: bytes=32 time=2001ms TTL=64
Reply from 192.168.0.120: bytes=32 time=1030ms TTL=64
Reply from 192.168.0.120: bytes=32 time=1ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=1528ms TTL=64
Request timed out.
Reply from 192.168.0.120: bytes=32 time=1048ms TTL=64
Reply from 192.168.0.120: bytes=32 time=14ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=3089ms TTL=64
Request timed out.
Reply from 192.168.0.120: bytes=32 time=122ms TTL=64
Reply from 192.168.0.120: bytes=32 time=3125ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=3212ms TTL=64
Request timed out.
Reply from 192.168.0.120: bytes=32 time=1231ms TTL=64
Request timed out.
Reply from 192.168.0.120: bytes=32 time=3256ms TTL=64
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=2276ms TTL=64
Reply from 192.168.0.120: bytes=32 time=752ms TTL=64
Reply from 192.168.0.120: bytes=32 time=1004ms TTL=64
Reply from 192.168.0.120: bytes=32 time=2006ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=347ms TTL=64
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=1396ms TTL=64
Reply from 192.168.0.120: bytes=32 time=2ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=11ms TTL=64
Reply from 192.168.0.120: bytes=32 time=1406ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=1482ms TTL=64
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=492ms TTL=64
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.0.120: bytes=32 time=2609ms TTL=64
Request timed out.
Reply from 192.168.0.120: bytes=32 time=683ms TTL=64
