trouble starting
gabijgg
Hi! I have this problem with my vu+ duo. When I turn it off with the autoshutdown or the shutdown menu and then I try to restart it, it not starts, only keeps the red bottom on the led and the hd starts working but do not start loading the system. I have tried to reinstall BH 2.1.7 but keeps the problem. What can I do?
Read http://www.vuplus-community.net/board/threads/vu-duo-is-dead.3616/ and http://www.vuplus-community.net/board/threads/sostituzione-condensatore-220uf-16v.6522/
thank you very much but I think it will be the condensator because when it gets the red light, if I turn it off with the back bottom, the device starts correctly.
Hi, I have gone to a electronic shop and they apply me the voltaje and specifications of the condensator. How can I know it?
Its written on the side of the cap. Get something thats the same spec, they should know this if they are even a basic shop.
Thank you for your post. Yesterday afternoon I solved the problema. I replace the condensator and my vu it´s like new!!
