Tune Failed
magmo
I have started to get message of "Tune failed" when I turn on the receiver from standby, then it disappears if I select a FTA channel, if I then go back to the channel that gave me that error the error is no longer there and I can watch the channel. Weird....
OBH 4.3.027
VU+ SOLO 2
OBH 4.3.027
VU+ SOLO 2
I have had the same error with my old Duo...the only way I used to fix by changing :
the DiSEqC
Before doing that, I'll be sure to exclude a software issue and I'd change image (for instance BH). You can install it in multiboot, so to try it without reflashing.
