tuner A and B
bady71
dear all ,
please let me know how i can set the tuner A and B on vu+duo
i have on cable from dish
how i can configure Tuners , that when i record form tuner A , i can wacth tuner B channels
please help
your reply with be heiglly apprecied
regards
If you have a single LNB, you have to connect the cable to the tuner A and setup the tuners in this way:
Tuner A
Configuration Mode: Simple
Mode: Single
Satellite: You have to choise your satellite
Send DiSEqC: No
Tuner B
Configuration Mode: Loopthrough
Connect to: Tuner A
thank you so much for your reply dear mito
in my dish's cable , i've lnb 1 and 2 ( lnb 1 with nilesate , lnb 2 with hotbird )
how i can set and configure ?? same as you said !!
thanks a lot for your assistance
regards
regards
If you have a DiSEqC switch 2x1, you have to set your tuners in this way:
Tuner A
Mode: DISEqC A/B
Port A: Nilesat 7.0°W*
Port B: HotBird 13.0°E*
Tuner B
Connect to: Tuner A
* Obviously, these values depend on the way you connected your LNB to the switch and therefore they can be reversed.
i should plug the cable in tuner A and B , or only in A ?????
If you are using a DiSEqC switch with only one cable
Then plug the cable in tuner A.
If you have two cables and no DiSEqC switch then one cable in tuner A and the other in B
In this case you have to config Tuner A for one satellite and B for the second.
thank you ,
i've only one cable , with lnb1 and 2
thanks , i'll try and come back to you with the result
with my warm regards
need to install any plugins or not ??
because i fellow the settings and when i make full auto scann , the signal bcome 0%
please help
regards
please help
regards
Try to reverse the satellite setup:
Port A: HotBird 13.0°E
Port V: Nilesat 7.0°W
i thing that i've problem with tuner ,
still same problem , when i make full auto scann , the signal become 0% after 2 ~ 3 minute scanning
