I checked the connectors they are ok. I swapped cables and Tuner A works fine with either of the cables.
If you leave tuner A un-configured you don't get any signal for definite?
Fingers crossed it ain't faulty for you mate, but for me its always been a knocked wire causing a bad connection, both times had problem I had been messing about with usb stick I leave in back of solo2 and knocked the wires coming into tuners.
This is strange.
You have 2 cables, the two tuners are configured in the same way, right?
If you put 1 cable in tuner A it works, if you put the same cable in the second it doesn't work?
Did it work with 2.0.4?
The only thing I can say, is flash back to 2.0.4 and see if it works ok still.
If it does, then you know it's not a fault with the box for definate,
Thanks Evo, I'll do that.
I don't think there is any way to scan the box and see if all the hardware components are ok ?
I'll go back to 2.0.4 and update you guys with the outcome.
I have to say it sounds like a hardware fault.
Contact the shop you purchased it from.
Guys, Just to let all you know that Tuner B died for whatever reasons. I sent it back to the guys who I bought from and I received the replacement today. I could be one of the very few unfortunates who had this hardware issue.
