Tuner config - single satellite
beka2
Hi all,
I am having some difficulties configuring the tuners in my Duo2.
I have 2 Twin-tuners and a Lnb quad (Fiber LNB from invacom).
4 cables to the tuner's inputs.
How should the tuners be configured if I want to watch, record and stream only channels from the same satellite ?
If you have a single dish, pointed at one satellite, then you go into the Menu, Setup, Service Searching, Tuner Configuration, and select Tuner A.
You then set this to Simple, Mode = Single, then select the satellite, e.g. Astra 2, 28.2E.
You can then set the other Tuners to Equal to Tuner A.
