Tuner Configuration
Supermario
Hi Guys
This is the 3rd Time I am trying the OBH 0.1, First previous two times (many attempt failed and finally had to return to BH 2.6.1.1) on my VU+Solo2.
Now everything seems to be OK, except the ERROR turner failed - Check Turner Configuration.
1) Installed the OBH 0.1 in flash - all ok.
2) Installed the same OBH 0.1 in Openmultiboot - all ok except the tuner failed keeps on coming.
Turner "A"
Configuration mode : Simple
Mode : DiSEqC : A/B
Port A : Hotbird 13E
Port B : Nilesat 7W ( shows 7.3W)
Set voltage 22KHz : Yes
Send DiSEqC only on satellite change : Yes
Note : Tried changing Port A to Nilesat 7W and Port B to Hotbird 13E - no joy :(
Turner "B" - Not Configured.
Please can someone tell me what am I doing wrong? with the Turner Configuration?
Never had this problem with BH images
Tks
Supermario
Hi Guys
Turner "A"
Mode : DiSEqC : A/B
Tks
Supermario
Most likely
satellites.xml (Port B : Nilesat 7W ( shows 7.3W)
does not match with the list that you use.
Upload good sat list or try to upload new satellites.xml /etc/tuxbox and reboot
satellites.xml you can make and download here
http://satellites-xml.org/
