Duo2 Tuner interaction (interferences)
oliskippy
Using my Duo2 with BH 2.0.5 and the integrated DVB-S2 Twin.
The first tuner is on ----> SNR 80% on channel A
But when the second tuner turns on (using PiP or streaming to VLC/Laptop)
the SNR of channel A drops down to 65%.
--> when I watch a second channel through the second tuner, the image quality drops and I get freezes. I optimized the antenna position, now it's acceptable, but same loss ratio.
Any one gets the same interference? Ot it's not the Duo2 but my LNB Monoblock.
PS: Duo2 otherwise is just perfect. I use it with another DVB-T and a USB-DVB-C (HD works)
