Tuner problem
goran samardzic
When trying to add satellites, i go: Menu/setup/service searching/positioner. Then when i try to tune i only get 3 satellites and they work fine. but cant seem to find more than that.
But at "tuner config" i can see all the satellites, the problem is when trying to add their position to the positioner.
/thnx in advance...
hi
if you have a motor dish,you have to choose the LNB 1 or other LNBs for every Sat and its better to use usal at first, then go to positioner and store your correct position and then go back to tuner confg and change the usal to your stored posithion for that sat
