Tuner server add to bouquet?
Jules
Hi Guys,
I am using BH tuner server from VU+ Duo to Solo via media player.
Is there any way of adding the channels from there to my normal bouquet please?
Thanks.
Regards,
Jules.
Edit by moderator: No links, please!
Hi Guys,
Thanks.
Regards,
Jules.
You can use the function "Remote Stream conversion" in the Solo box to import the channels from the Duo box and channels will be imported in the normal way in the Favourite menu of channel list.
Both boxes must live in the same network (wifi or wired are ininfluent but with wired lan you can see HD channels without problems)
Thanks for your reply angelofsky, but I have looked and can't seem to find "Remote Stream conversion"
option. Can you tell me exactly how to access it please?
Thanks.
Jules.
Thanks.
Jules.
Menu -> Setup -> Channel Search
I haven't a box in front of me now and I took the path from my memory :)
Thanks angelofsky, works great.
Quick question please:
Do I still need to have the tuner server activated to send channels this way?
Cheers,
Jules.
Thanks, thats great. Is this option only on the latest BH? I've never noticed it before in system searching menu.
Hi again Eragon,
I am having a little trouble setting up remote stream conversion from another box I have. It is a DM7025. When I set the IP password which is just "dreambox",
it keeps changing back to "setopbox" and then it won't connect. Can we solve this please?
Cheers,
Jules.
Remote channel stream converter is managed by a specialized system plugin.
I don't know if the plugin included in images different than BH can communicate between them.
In my case I use a Solo with BH as client and a Duo2 with BH.
Have you tried without entering any password?
No I havent. I'll give it a go. I have a problem with between the Duo & Solo now. I downloaded a few channels earlier to a bouquet and they worked through channel stream converter, now since trying to get the DM7025 working the Solo isn't working either now. I can download the bouquet to the Duo but when I select any channel it does not appear. What could have changed?
Thanks.
Jules.
Still struggling getting the solo to work with this again. Can't understand it.
I can download channels to it but none of them work. They were working before I messed with the DM7025.
The bouquet comes through but without the _remote extention. Any ideas please?
Solved it Guys.
Reloaded new settings to main box and used streamer over to Solo again.
Working great now. Don't know why that happened. Thanks to all.
Regards,
Jules.
