Tuner Server issues
sasagr
Hello. I have a vusolo with 2.0.8, tuner server enable and built.
In an another room I have a tv with a raspberry pi connected.
I mapped the tuner server in the raspberry in different way, one way is with samba.
This way I can see and stream all the channels but the streaming is not always very fluid and many times it keeps on freezing
I m sure this is not an internet problem or raspberry capability to stream video because it can play hd streaming video from other sources/plugin.
I had this issue also with previous bh version and always hoped to get it fixed but it does not look like it is happening.
I m not sure if I can do something in my box as setting to make it working better.
Hope somebody can help.
Thanks in advance
Regards
No I did not. I thought to use the LAN option without the need of using the upnp that requires more resources as warned in the description.
But if this can be the solution I will try it
I enabled mediatomb and mounted in my raspberry as upnp. I can see the bouquet and channels but they do not play.
I used again the pan option, mounted with sbm in my raspberry and they play fine today. I thought it could be because mediatomb was still enabled and then I decided to disable mediatomb (that I must say it slows down the general performance of the vu solo) and try again. They are still playing well without any problem.
I think I will still make some test during the day with mediatomb disabled, otherwise enable if I face some freezing. I will post the results here.
In any case I do not understand why I cannot play the channels via Upnp.
